marksparks2
🧲 New user
My question needs clarification. Maybe it could be rewritten.
This idea of creating soft magnetic stators has been about here before, but only in relation to replacing laminated steel stators.
Magnetism is not amenable to common sense.
I am constructing an axial flux motor to turn my telescope very very slowly. There are 32 magnets and 24 coils in two layers, nested by bending the ends of the coils. So 48 coils in total. Almost 100% copper fill air cored. 452mm diameter steel disc rotors. It is a 3 phase motor.
I am testing coil and magnet arrangement. I can get 200g force at 190mm from pivot from a rectangular coil. This is 0.38Nm from only about 0.5 watt. Per coil. The arms of the rectangular coil are between opposing ferrite magnets 10mm thick 20 mm x 60 mm. The coil is 8mm thick. The measured flux is about 1200 Gauss in the middle of the gap 8.5mm wide.
This is good and compares with the Planewave commercial mount which uses giant coils and neo magnets on only one side.
I have experimented with transformer steel between each layer of a coil winding. Thinking, why not? Cedric Lynch has steel between the conductors of his distributed winding.
With my test rig it was not obvious that any force at all was produced.
So the magnetic field was effectively shorted magnet to magnet and bypassing the coil wires?
And also a massive attraction between steel and magnets, with only one coil and magnet set, I can only speculate if this would even out and cogging would be minimal.
I connected the oscilloscope to the coil and passed a magnet over it. A twice as strong signal from the steel infill legs, as the plain ends. In a 14mm width of the coil leg, there is 7mm of copper winding and 7mm of steel in total. I should expect much more with the steel?
So how about using iron powder in the resin when making the stator?
I tried posting on the usual suspect forums and got pretty well mangled and closed down for asking a question demanding a bit of fundamental reflection.
Do magnetic lines of flux pass through the conductor, even if a permeable material is adjacent?
I have lots of photos but I'll wait to see if it's of interest as being loosely off-topic.
