Pylonflyer
๐ New-ish
- Joined
- Jun 21, 2014
- Messages
- 35
2023 Ouxi V8 20" Fat Bike 750Watt 48v - "Amazon Special"
Here's the story: Daughter's bike started to make a harmonic buzzing noise and loss of power after bumping into a friend's bike (kind of a mild T-bone accident, no one got hurt). Assumed it was mechanical issue, but it's looking more and more like a bad phase in the system after more testing. I think she may have over-amped something when she was power on into the other bike.
I tested the motor phase wires for burnt windings, and they seem to be within similar resistance. Pulled apart hub motor to check planetary gears, looks good. Smelled controller and tested the FETs, seemed ok but I'm not the best at diagnosing esc's. I'm pretty experienced with RC brushless motors and such, but these e-bikes are new territory for me besides building some scooters and e-skateboards over the years.
Took a chance assuming motor is fine, and ordered a new esc from v8fatbike.com based on their recommendations. They said my bike would be "V3" compatible (that's their terminology on controller versions see pic), and I got their "V8" controller which, on paper, is within the specs of the original model: V8S-500. Got the new controller and 95% of plugs and wires are the same, but there is an extra "alarm" 3-pin plug (see pic) that has 48v coming out, and the 9-pin motor plug is red inside vs black (original) (see pics at bottom).
Got everything plugged together and display comes up, lights come on, turn signals work, horn works.... but no throttle. Motor does nothing. I searched the interwebs for info, nothing helpful. Played around in Chat GPT for a long while and it said to "jump" the outer pins of the un-used alarm plug (see pic of jumper). Still nothing. Plugged the old esc back in and motor runs, but it's not healthy sounding.
Now I'm stumped. Can it be that the 9-pin motor order is not the same? Different sensor pin order? Or is the new controller not programmed for this motor? Emailed V8fatbike.com support and they said this controller should work. Are they totally inept in their own products? Highly probable but so am I.
Is anyone familiar with this motor/esc brand to where I may be missing a simple step in programming something in the display menu? Are these esc/motor combos not universal and I have to do a custom esc process? Get a universal esc (KT keeps popping up in my searches). Or, should I save myself gray hairs and stress and buy a drop-in 20" hub motor/esc combo from Bafang or something and just rewire the dang bike? The 48V battery is fine, btw.
Appreciate any guidance from gurus or fellow victims of this bike who have fixed something similar.
Original esc
New esc
extra "Alarm" plug, jumped outer pins per instruction
Original esc
New esc
