latecurtis
http://www.ebay.com/itm/Imperial-Electric-Permanent-Magnet-DC-Motor-Model-P66LR006-36V-3-6HP-/192280564776?hash=item2cc4d09428:g:XJIAAOSw4TNZleED
Any information on a motor sprocket for this will be appreciated. I am looking to do a 40 mph build.
http://www.ebay.com/itm/10-30V-100A-3000W-Programable-Reversible-DC-Motor-Speed-Controller-PWM-Control-/371521297570?_trksid=p2349526.m2548.l4275
http://www.ebay.com/itm/10-50V-60A-DC-Motor-Speed-Control-PWM-HHO-RC-Controller-12V-24V-48V-3000W-MAX-/301247561012
Perhaphs someone knows of a different brush controller that works but am not looking to spend much over $50.
Brush controllers greater than 1,000 watts are not easy to find but found two. Which one is better and will the 100 amp one do 2,400 watts or only 1,800 watts. I am looking for 40 mph so will need a minimum of 2,000 watts.
Also will the 60 amp controller burn out with a 100 amp motor as 60 * 44V or 12S LiPo fully charged = approx 50 volts. That is close to 3,000 watts. I cant support 36 volts as I only own 6S LiPo packs so the motor will have to run either 6S or 12S LiPo.
Gearing will be that sprocket on a 26" wheel bolted to a freewheel clutch IF I can get a 10 tooth motor sprocket that will fit on the motor.
Please let me know as I have several bike frames that should work but without at least 2 kilowatts and proper gearing it cant happen. Thanks.
LC out.
LC out.
