TheThirdWheel
1 W
- Joined
- Jan 31, 2014
- Messages
- 55
Hi guys,
I have a sensored Infineon 40A controller (12xIRFB4110), 36-72V connected to a Crystalyte X5304 and running at ~72V. It has just up and died without warning. The controller still powers up and activates the CA, but there seems to be no power going to the hub motor. A sensor got fried in the motor, and after replacing all 3 sensors, the motor still does absolutely nothing when connected to the controller when the throttle is applied.
I know that the motor should at least try and rotate, cog etc regardless of hall sensor and phase wire configuration. To make sure it was the controller that was at fault I jerry-rigged a cheap Chinese controller I got off eBay to the motor, connected the same throttle and battery pack, and it ran flawlessly (after figuring out the hall/phase wire colour coding).
So now my question is, what could possible be wrong with the Infineon controller? The MOSFETs are all fine according to the testing procedures here:
http://www.ebikes.ca/troubleshooting/BlownMosfets.pdf
The wheel also rotates by hand quite freely while still connected to the controller, so I do not suspect a blown FET.
I've checked all the capacitors and they're fine, with their ESR's within spec. The multimeter shows that all grounds such as the throttle, hall sensors, CA, etc (including that of the battery) are connected as a common earth but from what I've read it shouldn't cause any issues. I suspect that battery pack voltage is somehow leaking to the hall sensors since I once got a nasty shock while touching a hall wire and the frame, and also when a hall wire burnt through, the voltage/heat was enough to melt a small channel into the side cover of the hub motor! 5V at <1A should not be able to do that kind of damage.
Any help is much appreciated! Thanks!
