dmwahl
I'm working on a KMX eTrike, and have the majority of the parts purchased. The one remaining item before I can ride confidently is a rear torque arm. Since the motor I'm using should be capable of 100Nm, I wanted something fairly heavy duty. I considered the doctorbass torque arm (epoxied on) but don't want to deal with the epoxy. There are a few other designs floating around the forum, but none are quite what I'm looking for or don't seem available anymore so I designed my own. It will bolt onto the rear disc mount and has flats to drill a hole for a clamping bolt (M6). The clamping hole will NOT be drilled, as I'm not convinced it's necessary, but some people may want the option so I figured I would at least make it easy to add.
I'm tweaking a few dimensions to get the fit just right, but after I'm confident with the dimensions I'll have a small batch made. Material will be 3/8" (9.5mm) stainless and I'd expect to sell them for somewhere in the $30 range shipped in the US. It is tailored for the KMX frame, but should work on many other frames as well. This is not a sale thread, just one to document the design and gather feedback.
[EDIT] Sale thread here
Here is the profile of the design, can be used to verify fit on a given frame. Print it out at actual size and try it out. Warning: The paper version will not prevent frame, dropout, or axle damage.
[EDIT] Installed TA photos here
