bane77087 said:
How big of a scooter? whats the weight without the batteries and motor?
http://www.motorboards.org/index.php?title=Main_Page
not big. I think with Lipo, it is only 18lbs.
bane77087 said:
http://www.motorboards.org/index.php?title=Rubber_wheel_information
These look pretty small.
bane77087 said:
Whats the top speed you want this thing to hit?
10-12mph should be the max considering the weight and all.
bane77087 said:
Is it chain driven? if so how many teeth on the freewheel drive on the axle? Or is it belt driven?
Nope. Friction drive. It's not the best, but works.
bane77087 said:
Does it have a motor on it currently that you want to upgrade if so can you put the specifics of the motor- manufacturer, model number and wattage that you want to replace.
http://www.motorboards.org/index.php?title=Motor_Part_number
They use 2 motors, but I want to replace them with 2 outrunner motors. Most of the RC inrunner with sensors are 25mm mounting spacing between the holes. The one that comes with this board is 29mm, so If I want to use the inrunners, I will need to make some mod mounts.
bane77087 said:
What batteries do you have?
10s 5Ah Nanotech 25-50C Lipo. I also have 4s nanotech also 25-50C.
So far looking at what is available, I think I will be going with sensored inrunner motor
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9821
these are suppose to go up to 4s (14.8V or 16.8V hot off the charger). Add 50% on top of that, I think if I keep the current low enough I should be able to use it at 5s safely.
The goal is to make something that is super high torque but low speed. I want zip around campus and be able to climb hills relatively easily without worrying about burning out the motor. Yet I don't want something large such that I cannot bring it in the classroom.
This is the initial reason why I went with an outrunner (high torque), but I think I might be better off using an sensored inrunner. That way my custom controller is easier to design. I can also get speed out of it vs the sensorless version.
I am also looking at these inrunner sensored brushless RC motor.
http://www.shopatron.com/products/productdetail/part_number=S352X/135.0.1.1.62703.0.0.0.0?pp=10&
these motor might be better since they are assembled in USA and also have longer body, so there should be more copper in it to handle more power. Of course I will be going for the high wind version (6.5T)
