Thanks,
I was just reading up about that. "chain pull angle".
I imagine regen-braking would be one of the big reasons to aligned with the swing-arm-pivot. But other than that, it seems you are right about it not being a big-enough issue to see done on many motorcycles.
Mike Edwards said:EBJ said:How is it that a motorcycle can get away with having the pivot-point of the swing arm at a slightly different location than the drive-sprocket? Is the whole point of chain-slack to allow for that? Seems to me that having a jack-shaft at the same pivot-point of the swing-arm would be a better option, but I don't think I've ever seen that on a motorcycle.
Why not?
Do you think it is just adding too-much complication to have a second drive-chain, or... does having the drive-sprocket at a different location than the swing-arm-pivot actually provide some sort of benefit?
Having the swing arm pivot in a different position to the chain drive has advantages and disadvantages. If you read up on squat and anti-squat with regards to the suspension you will get an idea of what I am referring to. Ultimately the pull of the chain operates at a different angle to the movement of the swing arm/suspension so it can have a positive affect but generally it is considered negative.
The only electric bikes I've seen that have had the motor drive on the same axis as the swing arm pivot are Kingston University and The Danish Future Electric guys (http://www.futureelectric.dk). In theory it is the most desirable solution but it relies an awful lot on the flexibility and stiffness of the rest of the chassis. In my opinion nobody has managed to get the balance of the two right so far.
