It's slowly starting to come together! The battery pack is sitting lower than it needs to, so we're looking at how we can lift it up a bit. There is a potential ground clearance issue, but since the pack sits above the line of the two axles, we're probably OK. I'm more concerned about the main control box sitting between the rider and the pack. It's probably going to have to some up a bit anyway.
The subframe is from an old Kawasaki 636 which was lying around. Seems wide enough to fit a Rinehart controller at least. Randy has been working out the seat position relative to the bars and footpegs. It's nice when it starts to look like a bike eh?
In other news, Rod from EV-Power has been designing a BMS for me. It's capable of managing 192 cells, but I will only populate 168 of them. It will fit on the top shelf of the battery pack. I have also decided to scale down the charge leads so they can fit comfortably out of the pack. I still need to splice them into the Anderson SBS75s.
On the chargers, I've not yet come up with it, but I plan on taking advantage of the voltage divider feature for limiting the charge current. This way I can still get a charge in at shitty tracks like Wakefield Park without tripping the breaker, albeit at 1 kW...
Also I have got Full-Throttle to come up with a PCB for the high voltage stuff in the main control box. There is too much potential for shit to go wrong in there, so a nice neat PCB will be the best way to go.
