rio9210 said:This is my final setup with JP SPOT WELDER REV 2.0, as is stated on PCB![]()
Lenght of cable (10-25 mm) is 70 cm, as suggested by riba2233. The welder part is 20+50cm. Used two DINSE connectors (10-25 mm) with two brass tips soldered on the end of DINSE connectors (industrial solder process, not homemade - you have to find the guy that can do this for you). Heatshrink was used on cable-DINSE junction, and two brass battery connectors.
I could not get a set-up cheaper than this. Frankly speaking, I didn't get far from riba 2233's cost.
By the way, 6 nickel strips 0,15x8mm (soldered between parallel rows of 18650 batteries) carrying 5-6 A each one should be enough for a 10S6P 21 Ah battery, right ? I don`t want to bother with manually soldering copper wires if I can do the same job with the spot welder and nickel strips.
It looks fine, but I'm not sure about brass tips, please tell us how they perform
For that current, it should be fine!
