fredsparkle
- Joined
- Jun 4, 2012
- Messages
- 24
Since my pack is simple to reconfigure to a 12 volt configuration, I thought I would try a little experiment with a fully discharged pack at 11.1 volts.
I simply hooked it up to my truck battery with jumper cables.
With the truck turned off it showed a 10 Amp charge rate.
With the truck running it showed an 18 to 20 Amp charge rate.
Revving the truck showed a peak of 30 Amps.
This was with a 3S36P configuration and no BMS. Maybe a little prior planning would be to have a series of battery isolation diodes for voltage drop; that you bypass to control the charge rate.
I wonder how far you could go, holding up jumper cables and maybe a sign reading “Electric Bike Need a Jump!”
