jonescg
Hi all!
Well the House of Kat and Chris is now home to another electric vehicle.
Kat has been riding 11 km to work and 11 km home most days on her pushbike, and while it's not too bad, on a day like yesterday when it's 39'C it's not much fun. So we ordered an e-bike kit from cell_man at emissionsfree.com and it arrived just in time for Christmas
I'm the one who is responsible for it's construction in maintenance
but whatever. I have decided to use the drink bottle holders as the battery pack frame mount.
Paul built us an awesome triangular pack with a built-in BMS. This consists of A123 green cells, 4 P 16 S.
The BMS is on the underside, so once the whole thing is placed inside a waterproof box I'll cut a few holes for the hot air to escape. Then I will put a 19 mm square ally backbone on it to support the weight of the cells, and so it can slip into the C-channels on the bike. It's a convenient setup for ease of removal prior to charging.
I figured for someone who isn't full bottle on electronics, I put a a high-current (20 A, 277 V AC) toggle switch in place with the 100 ohm resistor across the lugs. This way, once the battery pack is plugged in the Caps are charging up, and after a few seconds, the toggle can be turned on providing full current to the controller. I used those 30 A anderson style connectors. They're alright, but man they are tight to solder and fit.
The *ahem* '200 W' perfectly legal in Australia motor
I tested the switch by applying a load (my trusty 40 W 240 V bulb). It came on when the toggle was switched on, and it came on when the toggle was off :? The precharge resistor is in parallel with the switch, so when the battery leads are plugged into the controller to complete the circuit, the precharge resistor immediately draws 0.5 amps. Then when the toggle is switched, we get an e-bike that is ready for riding with minimum spark!
So is it normal for this circuit to be able to light a bulb even when there is a 100 ohm resistor in series?
