After what seems like months of toil in my freezing garage (ok only every other weekend) I finally got my bike to a usable state!
The wiring internal wiring on the battery pack is horrendous - lesson to all - design simple battery packs and leave extra space for cabling etc!!
Controller worked fine on first power up - great considering I never tested it before re-doing the wiring and beefing up the tracks. The 900W charger from BMS battery also worked fine (luckily I opened it up before powering it up - the fan connector was loose and the output fuse, though installed, was not wired up - what do you expect from BMS battery?
I had my first real ride on the DH comp yesterday (I'd tried it on 36v,30A before - underwhelming) 24s lipo at 75A. All I can say is wow!
Even better than I had expected. Admittedly it only had a 9x7 9C mounted in it, so low end torque was lacking. But it handles really well (after much frustration trying to tune the inaccessible rear shock), well balanced, low mass distribution. Handling on the bike feels great, rear shock is performing better than I had expected, and front forks are also great (just a bit heavy). The width between the knees is absolutely fine, I don't notice it at all. The only time I notice the width is when I stand straddling the bike, but because it is really rounded it feels fine.
Gets to max speed of 65kph on flat sealed road, over 70 down a slight hill according to my GPS. Much faster than I want and what it was designed for. I'm happy with my choice of HT3525 now, although I haven't tested it, I just need to get it going.
After my 30km ride on my favorite MTB trails (done in about a third the normal time) I managed to get a 2cm pinch flat ( I was experimenting with the suspension and rode straight at a curb at about 45kph) - stupid in retrospect. The rear tyre was at 20psi with a standard 26" tube in the 24" x 3" razorback - the flat was no surprise I guess. So after an unpleasent "ebike-walk-of-shame" through the village (not the way I had envisaged my first trip through the village on the new bike) I squeezed in a 26" DH tube and increased pressure to 25psi. had another good blast around some other favourite mtb trails - but the ride quality was not quite as good - I think I'll go back to 20psi, should be ok with the thick dh tubes and normal rocks/bumps.
I'm defiantly going to turn off throttle regen - it is great when you are constantly hammering it, but as soon as you try to use it at low powers like a normal bike it is just a pain because you can't coast.
I didn't have much monitoring equipment on board, just a few temperature monitors, a cell monitor and a GPS. The controller never got hotter than 40degrees, the battery pack never got over 23, but the motor was a problem. Most of my ride had it between 120 and 140deg, I had to stop every now and then to wait for it to cool down. This was a pretty low ambient temperatures - maybe 10deg - there is still some snow on the ground in the forest behind our house! This is on a stock 9x7 9C motor (but with doubled phase wires) so I guess no surprises it was over heating.
Now come the questions, does anyone know what current saturates the 9C magnets/windings? I'm guessing something like 60A because I couldn't feel difference between 70% and 100% on the 3 speed switch apart from higher top speed. What about the crystalyte X5 and HT/HS motors, what currents can they make use of?
I'll try to get some pictures and maybe a short video next weekend
