kenwood96 said:Hi, are the heatpads doing great work with keeping the batteries warm ? At which temps do you keep the lipos ?
kenwood96 said:Are you satisfied with the zippy 's ?
I also wonder how much toe -in you applied on the front....
xenodius said:I have 3-4mm of toe-in and I've taken my KMX up to 52mph... uphill...
Glad to hear your batteries aren't sagging, my a123 pack has been great until I get well below freezing. Then acceleration suffers. 28mph top speed at -23C... though that's from BMS cutoff, it could go faster with a smarter BMS but this is healthier for the cells. Someday I may put together a heater and do a fancy build like yours Adam but it probably still won't be so polished.
adam333 said:Yes, this one is made of Nylon and solved my previous problem.
I will also take some time to implement a canopy and possibly a front suspension.
adam333 said:...possibly a front suspension.
I really like this. What was total time and materials cost?adam333 said:It took a while but here it is: The E-KMX canopy
Basically, this tadpole trike canopy could be fitted on any recumbent bike and it allow the use of a Windwrap.
With the Windwrap:
Without Windwrap:
Rear view:
To get on the bike, you simply release the 2 front clips. The canopy's rod are made out of Fiberglass and always return to their "straight" shape. This is also what allow the fabric to stay stretched. I tested up to 60km/h and there is no flapping noise or deformation.
Rear brackets that goes on the rack:
The waterproof fabric sewed: ( I bought a sweing machine and learned how to use it for this project )
Fiberglass rod assembly:
2 min Video:
[youtube]nz4fJd-S114[/youtube]
This is not my design though, I was inspired by Ed miller to create this canopy: https://tadpolerider2.wordpress.com/tag/recumbent-trike-canopy/
Marc S. said:Have a look at the (drop in) front suspension from ICE Trikes http://www.icetrikes.co
http://www.recumbenttrikestore.com/images/FS.jpg
I'm pretty happy with the front suspension in my ICE Sprint. You might also try 20" front wheels first.
I found very nice and sturdy 47mm wide rims here: http://www.classic-cycle.de/en/Ready-Spanned-Wheels-Rims-Parts/Rims/?force_sid=dc3dbb03a0a4c1e6ca22c581a9db8292
You got a pretty monsterous KMX there! Nice!
mclark999 said:I really like this. What was total time and materials cost?
Go for it! I've never seen or heard from a KMX trike with ICE front suspension before.adam333 said:Yes, thanks for the suggestions. I will definitively go toward an "ICE suspension"
Other KMX trike models use 20" front wheels already. As I understand they all share the same frame.adam333 said:I am not sure yet about the 20" at the front, I would have to try it I guess.
18Wh/km is not a bad figure with your studded rear tyre. I was expecting way more.adam333 said:I took a look at your blog, the Wh/km of your trike is very good. Mine is roughly 18Wh/km.... do you pedal to obtain those numbers?
adam333 said:I realy like your waterproof Givi E21cruiser cases...
On the web site, they are black and white:
Yours are fully black right ? And how much are those?
adam333 said:This seat is not the best... I badly need to work on a suspension or a better seat...
