marty
Spot welder details please.litespeed said:x
After I get them charged up ill just be waiting for my spot welder to arrive.
x
x
Its completely up to you how to do that. A set of balance wires are at +cathode and -anode poles, creating a voltage potential between those poles. Logical placements are on either each individual cell or on each series string (10 sets) or parallel string (7 sets). If your pack design is to string cells in parallel and then string those in series, then the latter would work fine. Your balance charger, if that is what you're using, needs to match the voltage and amperage characteristics of its target, different in each case. Programmable balance chargers can enable that.jitup said:Hello,
I bought 100 of these a couple months ago, and after months of testing, I am ready to assemble my 7s10p pack. I only have a one main point of confusion. Where do I attach the balance wires? What connector do you guys use for the balance wires at the end?
arkmundi said:+cathode and -anode
In batteries, the cathode refers to the entire positive plate, the terminals to which are exposed, the ends on cylindrical cells, but which internally is rolled and comprises a significant part of the battery by weight.In a device which consumes power, the cathode is negative, and in a device which provides power, the cathode is positive: http://en.wikipedia.org/wiki/Cathode
jitup said:Hello,
mistercrash said:jitup said:Hello,
I hope this makes sense. Like it was said, use any kind of connector you want as long as you install the matching connector on the balance charger. Pictured is a crummy drawing of a JST connector.
mistercrash said:Wow! Now that is embarrassing. There would've been some KFF on the drawing I made before. I made the corrections. I hope I got it right this time. You'd think I never did batteries out of Konions before. :lol:
riba2233 said:Dont waste your time, you will end up disappointed. Samsung 25R cells are pretty cheap these days, and you would need much less in parallel because they are 2.5Ah.
team_EMUS said:riba2233 said:Dont waste your time, you will end up disappointed. Samsung 25R cells are pretty cheap these days, and you would need much less in parallel because they are 2.5Ah.
Even when these cells are given fo free?
We could at least verify our design and have a decent battery pack to ride with this year... Perhaps not the best, but functionnal.
Doctorbass said:Ah haa. I know you dont bother with using over 2000 of these used 18650V cells because you now have the magic tool to match them :wink: ...
Doc
team_EMUS said:Doctorbass said:Ah haa. I know you dont bother with using over 2000 of these used 18650V cells because you now have the magic tool to match them :wink: ...
Doc
Indeed! Thanks Doc!
Doctorbass said:UPDATE 2017
How to disassemble MORE RECENT makita:
[see video in post above]
Enjoy !
Doc
