stancecoke said:be aware, your photo shows only the breakout board, not the BT-Module itself.
The tutorial, how to connect the module can be found in chapter 6 There is the link to an ebay-offer for the HC-05 also.
regards
stancecoke
WAIT!! Instead, ask your brother to program directly the LCD3!! We developed OpenSource firmware for LCD3, see here this user doing a review and see it using the LCD3 and you will see new menus on LCD3 that you never saw beforehonya96 said:I am trying to convince (or bribe) my brother to write a code for arduino nano, to send speed, battery bars, watts and motor temp ( for now) to LCD3, so it can work with any controller.
casainho said:WAIT!! Instead, ask your brother to program directly the LCD3!! We developed OpenSource firmware for LCD3, see here this user doing a review and see it using the LCD3 and you will see new menus on LCD3 that you never saw beforehonya96 said:I am trying to convince (or bribe) my brother to write a code for arduino nano, to send speed, battery bars, watts and motor temp ( for now) to LCD3, so it can work with any controller.![]()
Ok I understand and yes, that seems the best idea!! Good luck!!honya96 said:I wanted the arduino as kind of Cycle Analyst, so I connect things to it. Seems easier to me.
honya96 said:I guess its well documented here somewhere how to do it, maybe we can also reuse some code..
can you please point me to something what can help us?
Thanks a lot.
cpn said:I had phase to phase short on 18fet open source firmware controller. It looks like as a result transistor is burned. Can somebody point me on right part I am not sure if is Y1 or Y2
honya96 said:cpn said:I had phase to phase short on 18fet open source firmware controller. It looks like as a result transistor is burned. Can somebody point me on right part I am not sure if is Y1 or Y2
Will check that when I get home. :wink:
honya96 said:Valopallo said:Please explain, what would be the problem with the battery? I understand that 10ah isn't much range if drawing 40Amps from it but is there something else like heat problems involved when going this high current draw?
Also, what do you mean by; "But I am still not running it reliably on Direct motor" ?
Well, I know nothing about programing So I cant get it to run reliably, its still better Stock.
But Stancecoke Is running Direct motor with it..
You Have some Brand battery in plastic case with bms inside? Send photos maybe...
Overheating of the cells should not be that bad, but if it has 15A bms with 30A overcurrent protection, it Will shut off.
Valopallo said:Ok. Finally got the time to open the battery case. Do these pictures give any information about my BMS or it's overcurrent protection?
https://imgur.com/a/30EvYLc
EDIT: Found it. http://www.spardbattery.com/PW-10SM-30092-2-20
1N4001 said:I'm in the process of modifying my S06S for higher voltages. Can anyone tell me the purpose of C1/C5/C14? (https://github.com/KingQueenWong/bmsbattery_s06s_controller_hardware/blob/master/S06S-Controller.PDF upper right corner) I wonder if their voltage rating needs to be raised if the max input voltage is, say, doubled.
stancecoke said:honya96 said:I guess its well documented here somewhere how to do it, maybe we can also reuse some code..
Thanks a lot.
I think the Forumscontroller is exactly what you are looking for!
https://github.com/jenkie/Arduino-Pedelec-Controller
Sadly the documentation is mainly in german
regards
stancecoke
Yes, the FETs are controlled with around 15V from the LM317, however one leg of C1/C5/C14 (the negative one in fact) sits directly on the motor phase, so it must be involved in the load circuitry somehow.honya96 said:1N4001 said:I'm in the process of modifying my S06S for higher voltages. Can anyone tell me the purpose of C1/C5/C14? (https://github.com/KingQueenWong/bmsbattery_s06s_controller_hardware/blob/master/S06S-Controller.PDF upper right corner) I wonder if their voltage rating needs to be raised if the max input voltage is, say, doubled.
I guess they dont, Vbst should be from some regulator so it remains the same..
Surely you jest? The 12FET PCB extends the entire length of the case: https://opensourceebikefirmware.bitbucket.io/development/images/15-1.pngBut i dont recommend trying this. Buy 72v 12fet and cut case to ~50mm
1N4001 said:Yes, the FETEs are controlled with around 15V from the LM317, however one leg of C1/C5/C14 (the negative one in fact) sits directly on the motor phase, so it must be involved in the load circuitry somehow.honya96 said:1N4001 said:I'm in the process of modifying my S06S for higher voltages. Can anyone tell me the purpose of C1/C5/C14? (https://github.com/KingQueenWong/bmsbattery_s06s_controller_hardware/blob/master/S06S-Controller.PDF upper right corner) I wonder if their voltage rating needs to be raised if the max input voltage is, say, doubled.
Xnyle said:It would be easy to create another non technical dashboard screen.
But then its main purpose is to know and change what's going on inside that black or silver box.
For me it will replace the original display, there are cheap smartphones for under 50€/$ out there so i will just mount one of them and have more flexibility and insight than any commercially available display could ever provide.
For almost the same price that is.
Just have to find one that looks really crappy, so it doesn't get stolen :wink:
I would like to know more about some values and terms like: Correction value, Setpoint, PAS values
Offroad Enabled
I've welded the shaft and I hope this will work until I receive my new Sempu 3rd gen.![]()
