In that case you must ask yourself if it is the right display to flash..... my connector is not identical (my screen is 860C V1.2).
You mean that the 860C fits without any connector modification? So it is a display specific for Tongsheng?... finally I connected to the 8 pin câble (out of motor), connect on the screen and the throttle....
I use a later version (v20.1C.4-LCD3 update 3) than you and had the same issue more than once of seeing average speed instead of current speed. Each time it was my fault by inadvertently selecting average speed while configuring the menu buttons. This screenshot of the odometer field page is from my LCD3 manual. Maybe it also apply to your version?Hello.
I use TSDZ2 with KT-LCD3, assembled and flashed in 2019. I have been using the open software version 0.18.2 since the first use. This version is uploaded to both the display and the controller.
A year ago, I suddenly had a problem: from one day to the next, the average speed started to be displayed instead of the current speed. I think that maybe someone, for fun or out of ignorance, entered the configuration menu while I was away in a closed company parking lot and changed some parameter. But I am pretty sure that it wasn’t the case. Over this time, I have tried to dig into the settings several times and changed the parameters, but nothing worked. The problem occurred after about 5000 km, and currently, I have less than 6000 km on the ODO.
I am attaching a photo of the display at a standstill, indicating the average speed. I would like to restore the current speed display. If you have any experience with such an error, please let me know here.
Note: Group 7, option 0 is current wheel speed. Option 1 is average speed
edit: With LCD3 you should have posted to this thread instead TSDZ2 OSF for all displays, VLCD5-VLCD6-XH18, LCD3, 860C-850C-SW102. ?
On my LCD3 (as per my manual), short press the UP button followed by long press of UP button will cycle between average speed and current speed. Try that, maybe it works the same on your's?Thank you for your reply.
Group 7, option 0 is "Startup Boost function" in my software version:
Features and configurations for version 0.18.X
Contribute to OpenSourceEBike/TSDZ2_wiki development by creating an account on GitHub.github.com
So still don't now how to change. But... after your message I've noticed something what can be related to forcing average speed instead of current wheel speed. When I am going though ON/Off buton by next menu I see 7.1 (photo), not 7.0 which is in manual "7.1 Average wheel speed: The average speed since power on."
I would like to change to "7.0 Current wheel speed: Current wheel speed.".
So, how to force system to display 7.0 or somewhere also current wheel speed in any of fields?
Regarding place of posting: I've did it by mistake, please (admin) move the discussion there, thanks.
Happy to hear it worked! The settings menu is not intuitive. With only 3 buttons, they have to use combination of short and long presses.Awesome, you made my day!
I’ve used this software for years (since 2019) and been in the settings menu many times, but I never knew a double tap up short and long would change the subparameter.
Perhaps someone (like me) will come across this post via a search. After a few attempts, I’ve just successfully flashed it using a CH340. For a long time, I kept getting the same cryptic error message (which, by the way, Gemini translates brilliantly). The problem is that when the CH340 is also used to power the display – at least with my DC Booster – it simply crashes during the flashing process. I therefore connected my DC Booster (27V) to an external 16V power supply. It is important to also connect the GND of the CH340 to the GND of the external power supply and the display (but not Vcc, of course!).Flashing 850c with CH340 TTL
I have issue flashing my 850c with my USB to TTL board CH340
It has a jumper on 3.3v and VCC pin. As I understand it it controls voltage on the tx, rx pins and this is the same voltage as in CP2102.
Last time I tried using the recommended one but was broken (see posts on previous page). My local supplier had only this one, did not want to wait for new one from China.
This board works. Installs correctly. I installed the latest drivers. I set it up as in the wiki guide. Screen powers up and the tx,rx lights on TTL board start flashing, and the RX, TX counters on the bottom of the APT app go up in number.
When trying to use the apt app I cannot install the firmware. I only get one message in gibberish and sound like when you insert USB into computer. Then it hangs in waiting. See picture.
Any help appreciated.
