Powerhour said:
This awesome new color lcd states that it has the communication protocol supporting the tongsheng controller.. could the firmware be loaded onto one of these?
The o/s firmware is actually loaded into the controller not the display. The display you mention isn't supported by the fw and even if the comms protocol was similar you would probably have some other issues. Best to stick with a supported display, the lcd3 is the obvious choice here.
I see from other threads you are keen to use a torquesensor, I'm using the Sempu T4 t/s with this firmware and can confirm it works well with Stancecoke's branch. Be aware though that setting up the hardware and fw to get everything working well takes some time and patience, this is not a plug and play solution. Also developement of the fw seems to have pretty much finished and it can sometimes be difficult nowadays to get help when you run into trouble, however the wiki contains lots of good info.
In your situation I would be taking a long hard look at the TSDZ2..... :wink:
