Iambuilderman
- Joined
- Sep 1, 2020
- Messages
- 62
I have several motors, all selected from AliExpress for minimal width (I want 7 speed gears as well) and maximum performance vs price ratio:
1. A 1500 watt no-brand 3T motor with ferrofluid: comes from a totAl package of motor + controller + wheel + accessories that many sellers like pasionebike sell. Great value motor, phase wires are quite thin (2.5 mm2?). Currently connected to the modified kt controller. Handles up to 80 amps before phase wires start to heat rather quickly. Easily hits 72 km/h with stock kt firmware.
2. A 3000 watt rated 3t motor from the seller Suringmax. Also filled with some ferrofluid. This one is connected to my sabvoton. I run it at 8000 watt max (130 Amp peak). I think it is quite similar to the mxus 3k motor. I think MQCON would rate these type of motors at 2000 watt. It has a temp sensor and a spare set of hall sensors + cable. I quite like it, although it was not perfectly balanced (little shake).
3. A no brand 48v motor rated by the factory at 2000 watt. This is my secret find on AliExpress. I think the factory and seller don’t know what they are selling. It looks the same as the 1500w no brand motor, except that it has 50 mm magnets (55mm casing), over 6mm2 phase wires and runs very fast at 72v (3t). So my own rating for this motor is 5 kW, based on its size and ability to shed heat compared to similarly sized motors. It is very basic, with 1 set of hall sensors, no temp sensor and a steel inner structure. But it has large magnets and lots of copper, so I am planning to slam some serious power through it. Of course also with ferrofluid added.
So in conclusion: a bit out of the box motors compared to the general public perhaps?
