kudos
Hey guys, I have a question:
When you install a freewheel on a motor you can use a spacer between the side case of the motor and the back of the freewheel.
My crystalyte kit came with one and I used it on my first bike.
I've swapped it over to my new build and now I find the the freewheel is slightly tight against the frame.
You might just be able to make out the spacer in this pic.
What I want to know is, can you safely remove this spacer and just have the freewheel stopping on the side of the case?
This will give me a bit more room and perhaps stop the freewheel rubbing on the inside of the frame dropout...
EDIT: Couldn't wait for an answer so tried it out without the spacer and seems fine. There's even a small gap now between the freewheel and the frame, maybe 1mm.
Cheers,
Kudos
Cheers,
Kudos
