Kin
Hi.
So I'm looking to putting together a e-kickscooter modeled after http://www.evalbum.com/4020, except with lower top end (Maybe 25mph) and a somewhat lower class motor (60 instead of 80?). The thing is, I'd like to address some of the noise problems, and I'm scratching my head at that. By the way, I contacted the guy about the fact I would like to mimic the project, and a summary of his response would be "spread the EV gospel."
By noise problems, I mean, in general I'm trying to minimize the noise. I've been playing around with a crappy electric scooter, an offbrand of the Razor e300, called the R2 Agressor, that I picked up broken from craigslist and restored. It's rather clear that this escooter is too loud, and I want to make something as quiet as reasonably possible. One thing I'm presently considering is- will a belt train be much quieter than a bicycle chain?
Space is insanely tight with this escooter, so I am puzzled by how I might reduce the sound. conceivably I can add some dampening foam all around the motor [a with a little space between], but I dont know how much of an effect that'll have (has anyone tried?)- considering how careful I'll have to be to not allow it to overheat.
So, in summary I guess, can anyone point me in the direction to reducing noise on an escooter build like that? I'm also going to have to figure out how I can up the gear reduction, but, that's a different issue. Here's the most obvious thread I could find while searching ES, http://endless-sphere.com/forums/viewtopic.php?f=28&t=7582#p114370, but it really didn't help that much [perhaps I missed the message].
Thanks everyone/anyone for reading.
To Update:
---I really want to quiet things from the perspective of an outsider.
---Here are some recent questions from the thread (a few posts down):
1) Has anyone tried enclosing their motor with some fan cooling on one side, but otherwise isolated on other sides?
2) Can I use a more powerful motor, and less voltage? Presumably this is going to be a less efficient system, is there any way I can get an idea of how much less efficient? [**I am saying something similar to "Oh, I guess to make it quieter I need to make it more like a hub motor directly driving the system**].
-----> Actually, if anyone could guide me in the direction for understanding voltage and the rotations*voltage factor, then perhaps I could answer this myself. It sounds too simple for me to be saying "Ah, lets just run lower voltage and higher current for the same output at lower RPM."
------> My other thought is that controllers are less efficient at higher current. Is this where the caveat to the above problem is? My demands aren't in the 6kw range, much much lower for this project.
To Update:
