Jeremy Harris said:Bob,
Those eBay 3.3V DC-DC converters look like a bargain, but checking the spec sheet I've found that they have a minimum current output of 10% of rated output, which means that they have to deliver at least 2A all the time. I guess a shunt could be used to take the excess, but that seems a bit wasteful.
Had you got any bright ideas for getting around this snag?
Thanks in anticipation.
Jeremy
that spec is just the range over which they guarantee all the other specs. as far as i can see they work fine at a milliamp or even a lot more than 20A. they just might not regulate as tightly at a lower current but it is certainly not an issue with a battery charger. they are totally cool! i have as many as i want or i would not be telling you guys. if you could hook them up to ac through a fet voltage divider you might be able to run them without a big 48v supply but they will take 36-72v in and it does not have to be well regulated. he will only charge $1 shipping each after the first one and will give you free shipping on 50.
