OOOG.
I really need to get to work on remaking the BMX, because this is really becoming a hassle...
One of these pins has been bent for a while, but I THOUGHT it was the side that handled the throttle. Only the first, third, and last pins in that row are connected to anything. But NOOOO, it's the side with the hall sensors. This explains why it stalled if I gave it full throttle from a stop.
I bent two more pins somehow last week, and then it wouldn't run. That's how I discovered my throttle/hall error. This posed a very big problem, because I need it to get to work today, and replacing that many pins with extra pins taken out of the middle of the connector would have taken too long. So, seeing as how I needed this fixed NOW, I ghetto up a solution; I'll replace the pins with something else.
I was gonna use a cut up needle, but I couldn't get it soldered to the pin. Eventual cure? Replace the pins with solder. Yeah, replace them with one of the most flexible metals in existance.
(I'm aware I had issues using a screwed up, flat soldering tip near a chunk of plastic, thanks.)
Upside: It works, and doesn't stall anymore. Downside: I'm afraid to take off the battery again, which kinda kills the whole purpose of the rack.
OH WELL. Time for work.
