mwkeefer
damcard said:I have been looking all day at how to contain the fire between my legs (lipos) on my race-link build. I am leaning toward some rectangular carbon fiber tubes such as these. http://dragonplate.com/ecart/product.asp?pID=4309&cID=54 Its pricey, but if I cut them in 6" lengths and milled some simple end caps with an o-ring for weather proofing, I thought that would work. So, two per 6" enclosure. That would be a little over 6.5" x 2" x 4" per enclosure. I could still assemble the pack the way I pictured above, except for the center cells, which I could put two cells end to end in a 2" x 2" x 12" tube. Glue, screw, rivet them all together. I wonder if that would be enough to stop one pair of flaming packs to cause the others to flame up. I would guess no. If I go this route, I will have to sacrifice a couple packs just to see. I assume the carbon fiber tubes would insulate or trap the heat though as opposed to Matt's machined aluminum boxes (again, not sure). Not having run these batteries before, I am relying on them not getting hot. That is another reason I decided to keep my pack together instead of making swappable smaller packs, to limit how much draw any one pack will get. Mine are 25C. -David
Dont forget the exhaust venting away from you and the frame in case of a flame out... a nomex lining would serve as padding but also would contain the flames and heat protecting your ride and your legs.
Probably not needed though!
-Mike
