Hello
Well I pried a point-1 pack open in order to pop the battery pack and BMS in to a nice case with a switch and a fuse and a charging socket all built in, here you can see the pack split open, the space at the end is to allow the cells to expand (its polystyrene foam ), will post a picture of the box later.
The main bundle of cells (37V 15AH) are packed in beeswax for some reason? anyway we shall see how it goes, you can see the BMS cell monitoring wires coming from each one, the bms will be mounted on top of the cell behind an aluminium plate.
If we can get these packs sorted nicely Team Hybrid will be offering them as standard, I am not sure there is anyone else offering a high capacity lipo pack in a small frame mounted box with switch, fuse and charging socket? yet! ha ha.
Cheers
Paul
Cheers
Paul
