spdas
Aloha, all. My Lipos are loosing charge quickly when driving, (can only get 7 miles when I used to get 12 mile range)
1) 4 x 5000mah 4s = 16s system charging to 4.1 v each = 66.4 see below the actual battery
http://www.ebay.com/itm/2-Turnigy-5000mAh-4S-14-8v-20C-30C-Lipo-Battery-Pack-Losi-HPI-Venom-Redcat-USA-/131473796790?hash=item1e9c72eeb6:g:dPMAAOSwBLlVG0Og
2) I never overcharge past 66.40 v (my charger is constant Voltage and as the batteries become charged, the amperage goes down to .01 A) and max starting amperage is 10amps.
3) My controller shuts my system down @ 54v, so the batteries do not go below 3.37v
4) I charge a full charge 2 times a day plus maybe an "opportunity charge". Has then about 75 cycles on the pack.
5) There is no battery sag past 3.4v and all the cells are Top balanced to 4.10v
6) MY CA shows a current draw of 25amps when I am cruising at 30 mph and 15 amps at 20 mph. When "flooring it to 35-37 mph I draw 35amps (7c max then)
7) batteries are not warm.
Any ideas on what is going on? Should I go up to 10ah Lipo battery but the 5.0ah is good for constant 20c and i am no where near that.
thanks
Francis
thanks
Francis
