DanGT86
I have an old Lishui controller from the late 20teens. It has a pushbutton for a throttle. Its all or nothing. When pressed the NO button connects solder pad VL to ground. There is 5v on VL.
Anybody know how to convert this to a normal ebike hall throttle? The Solder pads are labeled VP ZF VL HV HX POR
Some of these locations are grounds and others are either 2.5v or 4.5v or full 5v. Experimenting with shorting them to ground I get slightly different wheel speeds but most of them do seem to have something to do with the throttle. This leads me to believe a variable throttle is possible since the speed and voltage seem to be correlated. The label on the controller says the throttle range is approximately 1-4v.
I found some pics on the web of this same board with wires on VP and HV. I get 4.5v between those locations. None of the pics show where those wires go.
I have not had time to solder wires to those locations yet to try a throttle. I figured I would ask to see if anybody know what any of those letters actually mean.
