magudaman
I have been using A123 Dewalt packs for almost 3 years now and I purchased them through Ebay retailers.
Cell Specifications:
[pre]Nominal capacity and voltage 2.3 Ah, 3.3 V
Internal impedance (1kHz AC) 8 m1 typical
Internal resistance (10A, 1s DC) 10 m1 typical
Recommended standard charge method 3A to 3.6V CCCV, 45 min
Recommended fast charge current 10A to 3.6V CCCV, 15 min
Maximum continuous discharge 70A
Pulse discharge at 10 sec 120A
Cycle life at 10C discharge, 100% DOD Over 1,000 cycles
Recommended pulse charge/discharge cutoff 3.8V to 1.6V
Operating temperature range -30°C to +60°C
Storage temperature range -50°C to +60°C
Core cell weight 70 grams[/pre]
Dewalt packs contain 10 cells and BMS unit. I currently am running 40 cell or 4 packs in series at 66v
Pack weight about 2.5 lbs
My tests with these cells:
Setup – Cells BMS are bypassed when discharging and charged through the BMS:
These cell were original used on a Schwinn S1000 scooter in parallel at 33v 8.4ah. The peak power they would see is about 150 amps peak.
Today they are run in series at 66v on a Crystalyte 409 with a 35 amp controller. I am running 26†wheels and can see about 30 mph 33 mph uploaded. I only get around 7.5 miles but average about 23 mph on my rides.
I have also owned a CBA since I bought these batteries and did intial controlled capacity tests:
Initial capacity test from 6/25/2006, Similar charts came from the other 3 packs:
Today’s test from 1/15/2009:
I would say there is around 500 cycles on these batteries based on my current riding habits and cycle count on my Cycle Analyst which has only been around for year and half. Almost all my cycles are 100% DOD.
Some of my packs came from tool kits from dewalt and I just ebayed the tools and cases. On one sets, one of the packs was not testing good. I contacted dewalt who promptly sent an entire new kit and a box to mail back the old one. Luckily I was testing the battery through the BMS.
Conclusion:
Overall these batteries have outlasted the vehicles I have put them in and are showing amazing longevity. They have also proved their great current handling and really have a flat discharge curve. As an investment these batteries were well worth the money in contrast to other chemistries and would probably be the brand i would buy again.
Conclusion:
