Deepkimchi said:
Bob,
I could have worded things nicer. I've been around construction types, probably picked up some bad habits.
BUT: Would like to know if you actually measured the surface temperature, or just calculated it. You just posted the temps on the graphs without any backup.
no problem, my friend. i am an ex-sailor myself. i measured the cell temperature with an IR non-contact meter, partly because it is so easy, and partly because any other method has a significant Heisenberg uncertainty. ( When i use a very accurate lm34 or 35 to graph temp, it takes some heat out of the measured spot on the cell and sends it down the wire, so the manual measurements with my ir meter that average a fairly large and repeatable area are more accurate. The meter matches my calibrated lab mercury thermometer within 0.1F but even if it did not i am measuring the cells with the same meter.
Deepkimchi said:
I don't sit on my cells. I do have a 40 A limit, do check my CA, and after running the bike rather hard for 20 minutes, I stop, open the cover up, touch the cells with my 98.6 hand, and they felt cool, consistently.
If you want to be treated like a scientist, you might omit the stuff like "fry an egg" on the cells, or talk about the "destroyed" cells with little smilies attached.
My comment about sitting on your cells was a misunderstanding of your statement that the bike 'hauled your 200 lb ass around". The other comments were my attempt at humor. I try not to take myself too seriously. I do not want to be treated like a scientist, even though i worked as an engineer and metrologist for most of my professional life. I want to be treated as just another guy with an ebike, and that is why i do my best to validate any measurements i provide, rather than have anyone just accept them, and why i have not asked that my name be colored as an expert or mentor.
I will not pay West Mountain Radio $119 for software that would let me use their thermistor to record temperature, and i do not think it is necessary to measure it more often than every Ah which is what i did, and am content to do manually.
Deepkimchi said:
And yeah, maybe you're right about me being pissed... just pissed away $ 130 on the great Infineon controllers, then find out about a week later there's a problem with soft start. I give notice I want to buy some cells on 17 May, nobody says jack, I buy them, then you come out with the "great test" a week later with your little smilies.
Maybe they should rename the forum Endless Vendors...
I am not a vendor. I do not officially sell anything or represent any product. I did briefly try to represent Lifebatt USA some time ago, but nobody ever bought any cells from me and i only built one custom pack. I parted ways with them over a dispute on warranty coverage quite some time ago.
I do some custom work and repairs, and i will be happy to investigate the soft-start problem you mention even though i have nothing more to gain from doing so than hopefully contributing to helping you become another happy ebike user. Please understand that is my only goal, and the reason i try so hard to make my tests completely unbiased. I believe you will find many people here with the same attitude as mine, and yes you will find some vendors as well. You will also find that vendors who are a bit too liberal with the truth will be called out and do not last long.
The timing of my tests was based on when i received a BMI cell from armin for testing, and on the recent improvement in my ability to provide the data after a medical procedure that has reduced my back pain tremendously. You did not buy the cells from me, or i would have advised you that there might be better cells available. I expect that the person you did buy them from could not supply you with any better product, and hopefully they did not represent the cells to be anything other than what they are. I don't know what you paid for your green cells, but i expect it was significantly less than you might have paid for the bmi grey cells. I have stated several times that the green lifebatt cells are a good product; the bmi cells are just better.
You would not expect the Ford dealer to suggest that LandRover was a better product and send you away. You would not take your car back if they came out with a better engine before you bought it, and you had not done the homework to learn about it before you purchased, would you? Would you then blame AutoWeek for not reviewing the new engine sooner or making sure you knew about it? I am just trying to help my fellow ebike users find the best batteries, and to learn the differences between the products available. I am retired, and this is just part of my way of earning my social security benefits.
Apparently i was wrong when i said i thought the BMI cells were made in the same PSI factory as the Lifebatt cells. Armin has corrected my misinformation. If i were a shill for BMI i would probably have known better, don't you think?
