Ypedal
100 TW
The Mighty Volt said:Has anyone here ever stripped down a Cammy_CC battery? If so, what did they find?
http://www.ypedal.com/cammycc/Index.htm
Not fun. :|
kilowatt said:I took apart a 36 volt 20 amp cammy to divide it in two for panniers. I found two 18 volt 20 amp batteries series connected into a 2S19P configuration. If your thinking about getting two 36 volt 10 amp out of it, then forget it. The number of individual cells is staggering but dividing it in two is fairly easy as long as your careful not to lift a spot weld while removing the duct tape; I did. Another thing to watch is your BMS sense wires. On my BMS I have two connectors; looking at the two connectors head on the pinout is from left to right. The large connector is on top and starts with pin 1 (channel 1) on the left through channel 8 on the right. The 4 pin connector on bottom is left to right channel 9-12. I got this info from cammy.![]()
I ran into problems trying to find a low voltage cell (within a large bank) so I decided to remove 60 cells to bring it down to 15 amps (I think). I'm still working on it but have decided to move to 48 Volts with 4 ea 12V 12Amp SLAs. I don't think I will invest in another battery from China, especially the cylindrical type; we need a US supplier! I hope this helps you out.
Dave
Battboy said:Just responding to the above Poster as far as finding a U.S. supplier.
DH
AndyH said:Battboy said:Just responding to the above Poster as far as finding a U.S. supplier.
DH
?? Are you confirming that your new cells are made by CammyCC? Or did I misunderstand to which 'above poster' you were responding?
I'm a 'US supplier' of cells - when I talk tech, I post on the forum. When I want to post something for sale I use one of the 'sale forums'. What am I doing wrong?
Andy
liveforphysics said:I like that those cells have a tab on each end. That makes a lot of sense from a design and performance perspective in a pouch cell. Kokam makes good stuff, I bet you will be happy with that pack for a long time.
That pack cost you a fortune though, both in labor and materials!
That's $4.20 per Watt-hour.
If I was looking to do a no-expense-spared 1KW-hr battery, I would use these cells:
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=11956
Then you would have 45-90C rated cells, and all the LiPo packs would cost about $1200 shipped.
Or, if you were looking to have the same 1,700amp peak discharge ability, but wanting to have over twice the pack capacity, you could go with these guys:
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=8586
Arranged 10 in parallel, 2x6s in series, and have a 44v 50Ah pack with 1,700amp discharge ability, for under $1,000 in battery cost (+$~200 in shipping). Then with 2,200watt-hours rather than 1,000watt-hours, you could have about 2x the range.![]()
LOWRACER said:.... Also I charge it with my pedal alternator.
If I am not lazy I've got an unlimited range...
