bzhwindtalker
[youtube]SXdnWRXgNG0[/youtube]
I have 10kW KEB and installed thermal sensor right into the windings of the motor to cut it off at >130C. One pitfall with Kelly is that it's 5v output is not so well regulated and temerature measurement can be very inaccurate.RalterWöhrl said:Hi everyone!
1. Motor Heat / lost efficiancy:[/size]
There where a few comments where I red about temperature and lost efficiancy issues with the BHT 48V 1000W motor and the kelly controllers. Did that get sortet out?
Adam recommends the Kelly KBS72121X,55A,24-72V, Mini Brushless DC Controller in his build list, is there anything to take care of before buying these two?
2. Thumb- or Twist-Throttle?[/size]
Is that just personal preference or where are the pros and cons for one or the other on hard ridden free-ride bikes like the LMX?
Coming from an 4wheel/ATV Backround I would definitly like thumb trottle more, however after speaking to a few really good pro MotoX drivers they all were like: "If thumb trottle would give any benefit, why would not anyone riders use it?"
bzhwindtalker said:The higher kv motor seems to heat quite a but less but we'll now for sure soon with better battery. Lucas will set up a 2.2 for him too with the 16 poles motors coming in the mail so well know the difference between the 8 pole 70kv I have and the new 16pole 70kv.
Adam
madin88 said:The advantage of lower poles often is more copper fill but what motor will produce the lowest heat at given torque output depends on phase to phase resistance.
do you have a change to measure it? Would be really informative. And also confirm the kV please.
Adam, thanks for the tip. I've been thinking of that too, but it will save only a couple mm and the top bearing will be exposed to water and mud. But no big problem, I've already bought custom 888 top crown, so I can fit almost any good headset up to 35mm stack.bzhwindtalker said:Dennis,
You can run sealed cartriges headsets without the top dust cover to gain some clearance, that's what I do on my setup, with a BBB headset.
Holy moterfuxing cow... Two options:querlenker said:Adam, do you know this? http://e-nolix.com ???
So it isn´t actuallybzhwindtalker said:I sold Christian a frame in december 2014, this is the frame I sold him in the video. He never talked about getting more frames from me.
Edit : looked trough emails, Christian actually asked to buy more frames, last email from him on Aug 6
I've got some good SKF bearings, so it's not a problem. Supplied bearings start to rub even under small axial load.bzhwindtalker said:I will do what I can to find a solution for you!
Adam
