onloop
- Joined
- Jun 24, 2013
- Messages
- 600
When is everyone going to realise these boards we (excluding some who choose to build ineffecient drive trains) build are not actually 3 or 4 kw. Nor would you ever want/need that it.
By default the vesc is set to 60A max. On a 12S skateboard this means the max watts is about 2.6kw.
Even Less on a 10S system.
You all should buy a watt meter!
On average a well designed eboard drive train is maybe around 500watts. Peaks of 1000watts. So peak of about 30AMPS (only 15 amps whilst cruising) on a 10S system like the space cell.
This is enough power to drop you on your ass and break some keyboard warrior bones.
The LG he2 in 3P (7.5Ah) can easily discharge at 8C without over heating / huge voltage sag.
So it can output 60A peak if needed. So it can output 2.2kw.
But this is generally not needed. Most people don't spend all day riding up hills.
Here is some video evidence showing realtime data of the power characteristics of an eboard. This board also had a 2:1 reduction ration. Which is not really "effecient" meaning the motor was under additional load. During the incline section it peaked at around 900 watts. [youtube]inj75Ku7KXU[/youtube]
LET ME REITERATE - EBOARDS ARE NOT 4KW!
