A First little about my build:
About 2 years ago I bought a 2017 Hyosunge GD250R to make an e-bike/motorcycle. It home stripped out of all the wiring and mechanical parts cleaned and replaced if needed. Made a new wiring harness and after a lot of tries and failures with different motors and controllers I ended up with qs138 70h v1 and Fardriver nd72680 (great controller ) dkd display and z6 throttle. All silicon copper wires 12-16awg. Main battery wiring 0awg pure copper silicon wire with 250a 550v dc breaker.
drive train: (temporary setup )
I cut the original motor and put sprocket 520 sprockets on where the clutch was (420 chain went bad every other week and 428 didn't make much of a different ) its on first gear and connected to the original drive train ( back sprocket I changed to 52 teets instead of 46 teeth ) and put new Pirelli tires
I am planning on changing the current drive train with stanalone menual transmission to get better efficiency , torque and speed.
Since I made this build on a strict budget I had to put a lot of work into it, that way I can keep the quality of the parts high enough and not break the bank, and avoid unnecessary headachs in the future.
Next post: The battery
