Looking for Custom 7-speed Freewheel Gearing
Delray Beach, FL
I was wondering where I could get a 7-speed freewheel made w/ custom gearing. I basically want to replace one of the low-speed gears with a higher speed gear since I tweaked my eZip Trailz to go faster. Originally, the bike came with a 14-34T freewheel, but after I upgraded the bike to 36V I got a 11-32T freewheel online.
The original 14-34T freewheel has 34, 24, 22, 20, 18, 16, 14T gears and the 11-32T freewheel has 32, 24, 21, 18, 15, 13, 11T gears.
With the 11-32T freewheel, I find I need a gear between 13T & 11T when I pedal at my preferred cruising speed of 23-24 mph. I would like to add a 12T and remove the 32T since I don't need that gear in FL. Looking for a place to provide me w/ such a freewheel or the items needed to do it myself. Thanks.
No, no custom free wheels that I know of.
95 % of the ebikes here have enough power that "splitting hairs" isn't necessary
Can you change the chainring?
You might have a very hard time finding some one who will do that for you and if you did, chances are it'd cost you $$$
Have you considered changing your crank's chainring instead? It would probably end up being a much easier and cheaper alternative.
At a guess, i'd say you are currently using a 32t chainring? 34t chainrings are quite common and can be found resonably cheaply.
http://www.ebay.com.au/sch/items/_W0QQ_sopZ12?_nkw=34t%20chainring&_fromfsb=0&_trksid=m270.l1313
http://www.chainreactioncycles.com/Models.aspx?ModelID=28192
http://www.chainreactioncycles.com/Models.aspx?ModelID=3323
http://www.chainreactioncycles.com/Models.aspx?ModelID=3324
You'd just need to figure out how many bolts and what PCD your cranks are :)
Assuming you have a 32t front chainring, your current gearing would be:
32/11= 2.909 : 1
32/13= 2.461 : 1
The gearing you'd like to achieve:
32/12= 2.666 : 1
The gearing you'd have with a 34t:
34/13= 2.615 : 1
Not perfect but damn close :wink: Another advantage is being able to use the 13t instead of the 11t or 12t sprocket. This should (in theory) take longer to wear out and if pedalling hard over rough ground, be less likely to skip too.
Paul :D
EDIT: Took too long to type post, motomech beat me to the question of chainrings! :shock: :lol:
Exactly, try a different front ring tooth count.
FWIW, I've taken various freewheels apart and swapped sprockets between them to get different sets of gearing. If they are all shimano clones, they all tend to have the same splines. Same thing for cassettes. Taking them apart usually just requires two lengths of bike chain and a piece of steel flat bar with two holes in it so you can affix the chain to them (or go buy chain-whips).
If the one you need to change is the very last one, the smallest, then it is threaded on rather than splined, and these do not all have the same threads or at least not the same diameter of threaded section, so that can be a problem. Sometimes the second one in is also threaded on.
Ebike.ca sells a 7 spd 11-32 freewheel for 26$
Part number: FW7Spd1132
I don't find any advantage changing that standard ratio
As previously suggested, change your chain ring if you want better.
Thanks for the feedback and info. I didn't consider the chainring since I was only looking to change a single gear in order to achieve a more comfortable pedaling rate in the 22-24 mph range. I'm happy with the rates for the other 3 or 4 gears I use of the 7-speed freewheel. I find I get the best range if I keep the bike in that 22-24 mph area. My problem is that I need to pedal a bit too fast using the 6th gear (13T) and I'm pedaling slower than I like if I use the high gear (11T) - plus there's a bit more pedaling torque using the high gear that I would like to reduce and figured a 12T would be perfect.
The Currie eZip I got has a 44T crankset and I would be concerned how changing it would affect the other gears I'm content with. I figured changing one gear would not be that hard or uncommon - especially with a Shimano.
Looking online a while back I found a doc on disassembling shimano freewheels but can't relocate it. I also found some info on http://sheldonbrown.com/k7.html#hyperdrivec that talked about custom freewheels and it didn't seem that big a deal. Here's an excerpt...
Shimano wants you to use one of its standard combinations, and offers a wide-enough choice to suit the needs of most cyclists, but you don't have to if you don't want to!
Shimano cassettes that don't use spiders have most of the sprockets held together by 3 small bolts or rivets. These are not essential. Their function is convenience, in allowing the cassette to be installed slightly more easily. To make a custom cassette, you will often need to remove the screws or rivets. Just discard them: they are unnecessary in practice.
* Some cassettes use screws with a 4 mm hex head. These can be removed with an adjustable wrench.
* Some cassettes use screws with a 2 mm Allen head. These are frequently mistaken for rivets.
* The easiest way to remove rivets is to grind off the heads where they protrude from the largest sprocket. I generally do this on a bench grinder.
It is not difficult to customize Shimano cassettes. If you substitute an un-approved cog, Uniglide or Hyperglide, it will still work, but the shift to/from that cog will probably not be as smooth as a Hyperglide shift normally is. Since people managed without Hyperglide for several decades, this shouldn't scare you off. In particular, if you substitute the top or bottom sprocket, you will only have one shift that isn't HG; shifts to or from the extreme sprockets tend to be less troublesome than intermediate shifts anyway.
For example, Shimano doesn't make any true "corncob" (one-tooth-jump) cassettes for time-trialists or flatland riders. In 7 speed, the closest is the J (13/14/15/16/17/19/21).
If you remove the 21-tooth sprocket from a J, you can make it into a 13-19 corncob by buying an 18 to put between the 17 and the 19. Alternately, you could make it into a 12-18 by removing the 19 and the 21, and buying a 12 and an 18.
Similar modifications can be done with other ratios. Generally, the smallest sprocket needs to be one with a built-in spacer, designed for the top-gear position. While you can't insert or remove a sprocket within a spider module, you can add sprockets on either side of these modules.
For example, if you want a 13-32 9-speed, you can start with a 12-27:
* Replace the 12 and 13 with a top-position 13.
* Add a spacer and a 32 after the 27
(you don't need to buy the spacer, because you can use the spacer that came between the original flat 13 and the 14.)
There is no problem mixing 7-speed or 8-speed flat sprockets into a 9-speed cassette, or vice versa. The smaller sizes (11, 12, 13) that feature built-in spacers should ideally be matched, but even this isn't generally a problem in practice. If you want to get finicky, you can compensate by using a wider spacer next to a narrower sprocket, or vice versa. On the other hand, if you use 9- or 10- speed sprockets with built-in spacers in a 7-or 8-speed cassette, the spacing will be too narrow for the wider chains used with these sprockets. You should use only 10-speed sprockets in a 10-speed cassette, because the internal width of the chain is narrower.
So it seems either the chainring or sprockets can be changed. Provided I can find a 12T gear, I'm more inclined to see if I can change a single freewheel gear rather than the chainring which would change the pedal rates for all my gears instead of just one.
Yes, we know all that.
"Cassettes" do not fit Ebike motors. You are using a DNP FREEWHEEL, which does not come apart easily.
If you go with an 13 or 14 T Shimano freewheel, you will then need at least a 48T chainring, which could cause clearance issues.
Better to go with a 40 or 42 T chainwheel and keep the DNP.
No reason at all to "worry about the other ratios".
Just use the SB gear calculator to determine what size chainring will put you in your comfort zone" and be done with it.
