Hello,
I recently ended up replacing the m600 reduction gear and controller. I think I burnt the controller because I connected the motor before disconnecting the battery. I also had the controller calibrated but for some reason the speed is not being sensed even after replacing the speed sensor. There is a 2 wire wire connector in the motor connection compartment with small black wires as shown in the attached image.
What is that for?
Does this motor have hall sensors?
In the process of closing the motor I had the two wires pinched but I did repair that connection. could that have something to do with the motor not sensing the speed?
Or would do 2 black wires be for the torque sensor?
and would a bad torque sensor be the problem?
The best tool did not throw any faults. Also when it was being calibrated the motor ran smoothly through the Best tool.
What is that for?
