Arbol said:
d8veh said:
Most people here seem to be comparing the Bafang BPM with the MAC. Greenspark's comments are very valid: things have moved on at Bafang, and we now have the 500w CST motor. It isn't just a BPM with a cassette spline. They completely re-engineered the motor. The build quality inside is, to me, a step-change from the BPM and Mac. I've not heard of a single problem reported with it yet, and most important of all, that cassette spline allows you to have proper quality gearing
Interesting, thanks. It seems the CST is ideal: robust, light and it accepts high power.
I have been looking around, and I only can find a CST (36V) at BMSbattery. Is there another webpage to buy either the CST or the Xofo? I am based in Europe, but I could buy elsewhere.
We have both the MAC and two CST units, one 12T one 14T 36V. The first difference is the cluster. MAC takes a spin on, CST takes the cassette type. MAC provides a good cluster that has a smaller small gear so you can keep pedalling at speed. If you want to change gear ratios, with a cassette you can do so, with the older spin-on type you don't. However, in real life most folks install the cluster and that is the end of it, so its more a matter of whatever your bike comes with, or if you buy from Cell Man, have him pop one in the box.
The CST is smoother and less powerful. The MAC is slightly beefier feeling, and has more grunt. Not sure what makes the difference, but again, it's subtle. For CST think Pierce Brosnan as James Bond; for MAC think Daniel Craig. I should note that the CST was hooked up to the Bafang Z01 controller after we found something in three K1200 controllers was conflicting with the BMS whereas the MAC runs on an Infineon controller that Paul set up. Bafang does not make it easy to program their controllers (you would need to hack them on your own); Paul sells a cable to hook the Infineon up to a laptop. Are you beginning to see the difference between MAC/Paul and Bafang yet?
If you are based in Europe, your first consideration (presuming you will use your motor on the public road) is to ask if being legal is important or not. MAC is for enthusiasts - 350 and 500W, CST offers a 250W Euro-legal version that gives decent power.
To find vendors for the CST Google
Bafang cst motor and you will find most of the usual vendors, not just BMS battery. Most recently we used http://www.greenbikekit.com/index.php/electric-bike-kit-1/rear/8fun-cst-e-bike-kits-36v-250w-350watts.html and like them. However, your big question will have to do with shipping. We can't help wondering if the low-priced Chinese vendors are not earning their profit on the shipping charges. The costs range wildly and can be substantial; if you order the kit with a laced 700C or 26" wheel, the bulk increases the price. When we put an order in with BMSbattery and selected a shipper and paid, they then came back to say that option was not available, and we owed them more money. The same happened with ecitypower.com. The only one who seems to pay attention to shipping is Paul (Cell Man) who can offer surface shipping that takes longer but saves a bundle. However, he offers MAC not CST. His batteries by the way are excellent... more expensive but worth it.
Another option to consider: the mid-engine. When we were in Suzhou in January Bafang invited us to hop onto a test bike with their new BBS01 crank motor. In March, we took delivery of two to test, a 350W detuned to 300W (to be legal here) and a Euro 250W (except that it also had a thumb throttle, which is legal here). We installed them on standard bikes; first a Bella Ciao, and last week put the 250W on a 1951 Raleigh DL1. We think they are fantastic to the point that in NZ we are now recommending them over hub motors.
Installation is simple: one removes the cranks, BB and chain ring, and slips in the BBS01 kit motor that comes with its own 46 or 48 tooth chainring. The controller is built in to the unit. See http://szbaf.com/product.asp?id=22. Also Google will find a number of German videos showing them. Bafang pays a lot of attention to Europe.
Since the motor drives the chainring, it uses the bikes rear gears, so a lower-powered motor can torque you up a steep slope the same way a lower gear on a car or motorcycle does. It is smooth, quiet and uncluttered. It also is fairly subtle. It is ideal for a derailleur cluster that can be shifted while pedalling. On a Shimano Nexus (Bella Ciao) or a Sturmey Archer S3X (Raleigh) we have to stop the motor before shifting by lightly holding the ebrake handle, or we need to plan ahead so we are not needing to shift whilst under power.
It appears that it was inspired by a Japanese motor (almost identical looking), but it does appear that in 2013 Bafang is taking advantage of automation to put out some fairly good product. We read that they recently introduced a 750W version as well. Not sure who is offering them for sale, but here is one on eBay DE http://kleinanzeigen.ebay.de/anzeigen/s-anzeige/bafang-8fun-bbs01-kurbelantrieb-motor-pedelec/131662332-217-8599?ref=search
The good news is that in July 2013, there is more choice than there was a year ago. The bad news is that it requires more research to sort out what you want.
