grindz145
wtf! Is that a SepEx D and D?methods said:BAH!![]()
-methods
-methods
I know that feeling. I spent the last two evenings repairing my Fechter/Goodrum BMS after I carelessly crossed two cell taps. I just got it working again and was about to finish for the evening when I thought I'll just turn down the finishing voltage on the charger a touch. Did that while the charger was live, of course, but then decided to refit the cover while it was still live. Bang!!! Buggermethods said:Unfortunately I must admit that I destroyed this motor out stupidity - not by pushing its limits - and that is the last I want to talk about that
dbaker said:Want to consider a 3phase induction motor driven by a VFD? It would be the same digital programming issues you have mastered for ebike controllers setting up the VFD. Problems are the higher DC voltage to drive the VFD but a 230vac 3 phase motor will cost a lot less than the one that blew.
Dave
Jeremy Harris said:I think that this deserves one of these T shirts:
dbaker said:There were a couple of Australians using Danfoss VFD's and SLA batteries in 4x4's and pickups.
Next big mod is to add forced air cooling to the motor.
methods said:Luke is trying to convince me to use some ridiculous 2KW 5" RC ducted fan....![]()
Probably blow hard enough to shoot the brushes right out the other side of the motor.
AussieJester said:HAHA likely his intention, Luke doesn't like brushed motors much from what i have read![]()
AussieJester said:Did you have your fans all blowing in or in a push pull setup Patrick? I think smaller ducted fans in push
pull config would be the way to go, they also sound trick, you would sound like a plane humming down the freeway hehehe
KiM
When you do, how much for the frozen up one? Keeping in mind you can probably find another buyer before I can scrape up money.methods said:
I have a couple of these sitting around if anyone is interested.
One is in good shape - the other is frozen.
Have not even looked at them - got them as part of a lot I bought up.
Still not reading PM's
