First, powering the front wheels on anything fast that has the rear wheels powered is useless. (front wheels should be in the air on anything RWD and fast)
Second, the torque production is very much related to motor physical size. Even if you have a magic motor and controller that has infinity current and current handling, and infinity cooling, you are still bound by the strength of the magnets in the rotor to push your field against (and by stator tooth flux saturation etc). When you're looking to push a motor hard for racing, you have defined torque limits based on the size of the flux area, so if you want to match a geared motors torque, you gotta get that flux gap area physically as large as the size increase to match the geared motors advantage to equal the torque and power.
It's why a little geared hub can be 5lbs and match the torque of a 15lbs direct drive hub.
Torque * RPM = power. Anything you can do to get that RPM up is a good thing. Direct drive hubs means the first part of the track is going to be at like <5-10% efficiency, and off the line you're at 0% efficiency. You could spend those same amps and voltage into something that gets into an efficient RPM range 1/6th sooner with a rear-end, and get to use a lot lighter and more compact high RPM motor to milk power from.
Plus, for me, I've broken every sort of CV shaft and diff and axle and suspension control arms and suspension mounts on the chassis etc.
Just knowing you can spend just $3k to permanently end all those types of failures makes me froth at the mouth for building a sick RWD electric dragcar, where your only concern becomes burning up motors and controllers, rather than breaking the drive-train AND motors and controllers.
