To make it fit in the car? Isn't that a lot of work? How about finding a car that fits the scooter?Solutions I am thinking of:
1. Cut the frame at the middle to make the length shorter (and with soldering reinforcements)
I've read a DD rear hub motor can easily run at some percentage higher power than spec (50%)?Yes, I think the must upgrades are adding foot pegs and more powerful motor(s) and battery. I think the frame is good.
Can I change to a different controller as a start to get more power? I just need it to go around 20 mph, not bog down on 10% grade hills.
VESC will have a big learning curve for me. I also do not have Windows.Yes, I think the original motor can run at a bit more power, but on that case the temperature control is a must!
I would go with the VESC 75100 that costs about 60€ only.
Here a tutorial how to install the VESC on EScooter:
I am using Linux, for instance, no Windows.VESC will have a big learning curve for me. I also do not have Windows.
Thanks for the tips on how to add a shunt. Can you explain the theory behind it? With the stock controller, I saw 15A max on my clamp on ammeter. After shunt mod, should I see higher current draw?The shunt looks easy enough to get to. The problem is its hard test what the new current limit will be without running it. If the limit is too high, something will fail. But that's always the case with shunt mods.
If I was going to mod that one, I'd take a small piece of copper wire and solder it between one end where it attaches to the board and the other end somewhere near the middle. That should give you a little less than 2x the original current limit.
@mrmojorising Can you post a link to a non-vesc controller? Is that what you used in your Fiido Q1S video?@Zambam flipsky also sell their own non-vesc controllers which are basically a dumbed down version of vesc. I recently completed a fiido build using their ft85bd dual motor controller, it was very easy to setup and significantly improves performance and customization without the increased complexity of vesc (Fiido Q1S Modded with Flipsky FT85BD and custom 46950 72V battery)
Just throwing it out there as a cheap alternative for a customizable controller
This is the one I have for dual motors: Flipsky FT85BD Dual ESC 84V 200A With Aluminum Case NON-VESC For Electric Skateboard / Electric Scooter / Ebike Speed Controller / Electric Motorcycle / Robotics@mrmojorising Can you post a link to a non-vesc controller? Is that what you used in your Fiido Q1S video?
Gave it a test ride! It definitely gained more power in terms of acceleration and hill climbing. Top speed still limited to 15 mph. Unplugging a single white wire connector from the motor harness didn't help.Looks good. Try it. You could adjust it by moving the spot where the wire attaches. Problem is if you go too high, something will blow up.
Yes.I've read a DD rear hub motor can easily run at some percentage higher power than spec (50%)?
Yes I do feel, and that makes me nervous!! I always feel unsafe, dangerous and I can't ride relaxed.@casainho How does your i12 ride and handle? I find my i12's front wheel feels light and twitchy. Maybe I just need to get used to it or is there some adjustments that can be made?
Thanks for sharing!!My old Vego scooter had twitchy steering like that. Almost impossible to ride with one hand.
I took apart the fork and flipped the top part around to give the wheel more trail. This helped a lot.
Tires can make a big difference too. Avoid anything with a square-ish profile.
Yes!!No pedals on these! My bad, sorry.
Principle still applies though - anything you can do to shift your weight forward will help.
Looking at the steep head angle, longer springs won't help enough either - you really need to slacken the head angle by bending the frame.
