Well, the 18fet was riveted into the steel plate that you see in one of those pics...and just for extra precaution I got those metal straps. as for the kelly...which is significantly bigger, will still fit on that steel plate. it's got 4 holes and i think the 1/4" bolts i have will do just fine. I'm not to concerned with heat sinking and all that jazz. I shouldn't been pushing this thing very hard since its rated for 100a continuous and 250a max for 1 minute. That'll be legit.
I picked a few goodies...
- gopro 2!!!! so pumped! its frickin awesome. I picked up the outdoor edition and i got the k-edge mount...it better be 50 bucks beyond amazing since it was 50 bucks.
- Methods' parallel boards...so that i can get rid of some of jst wire mess i made. I'll put 4 packs into each parallel board and leave the jumper for my icharger, that way i'll have to deal with 4 main jst connectors for parallel charging
- kelly 96251...So badass...i haven't waterproofed it, since they only had the non waterproof in stock. Fany told me to add silica gel somewhere and he says I have to take it apart...what?? anyone know anything about this? The j2 connector was custom so that i could minimize soldering....as you see in the pics....there are a few leads with the ring connectors...do i have to keep them separated when i use the controller? shorts? since i don't think i need them... You can see waterproof hall housing connectors...I'm also not gonna use the j1 connector..
- EV200 kilovac contactor (on the way)...so i'm starting to believe that with my luck, i'll totally blow everything up..and when I mean luck...I've sort of felt this invincibility cloak since i got into EV stuff. But recently, i saw a patient that had electrical burns.... that night i began thinking about how much voltage/current i'm "playing" around with and realized i could totally fry myself. So...I'm looking for a better charging solution...One that i don't have to unplug very often. HELP?? :?
I currently have 4 series harness each with 4 packs. when i charge, i parallel charge each 4p pack, which means i need to disconnect 4 packs and plug em in to the icharger. I was thinking about getting a bmsbattery.com charger to bulk charge. But i'm confused about how to wire the contactor into the system and charge without ever disconnecting. HELP?? :?
