Routybouty
It's probably dead. Yes you can skip a board. Check the voltage first!!
You can skip it, but you have to configure that board to zero cells in the bms menu.moonshine said:So if I started seeing smoke after plugging in the second plug is it safe to assume it's dead? Is it OK to just skip that board and resume plugging in the rest of the packs on the third board?
moonshine said:I changed my settings to the 10k temp probe and it read up to 180 today when I was doing full speed runs in traffic and on the trails.
What is a safe setting for max temp? 212F?
ozman said:Nice work you gotta be happy.
Can you provide a link to where you got that charge plug with the flip cover it looks good i would like to get one for my bike
beast775 said:Sure 212f and you can boil a tea while your waiting for the hub to cool down.
I really like your build its my favorite so far for, hub-wheelbase- looks-battery-bms-fork-tires -special add ons..dont melt it! :lol:
ohzee said:You should see the lights on it flashing as it balances. I think there is a setting to turn it on in the setup somewhere , but not sure if I actually had to do that.
Love the build. Our setup is pretty similar , but I think I have a 5t as far as batteries,controller,motor go.
dbaker said:Where did your wife sit on the bike?
moonshine said:ozman said:Nice work you gotta be happy.
They're connectors typically for high quality audio stuff. A company called Neutrik makes them. The connector i used were 4 pole connectors (4 slots for 10awg if soldered or >12awg if using the screws on the connectors). The part that plugs in is a NL4FX connector:
http://www.amazon.com/Hosa-Technology-NL4FX-Connector-Speak-On/dp/B002BERXW6
The port that it goes in is the NL4MP-ST (screw version not the solder tabs)
http://www.amazon.com/Neutrik-NL4MP-ST-Speakon-Panel-Mount/dp/B00067JSFA/ref=pd_bxgy_267_img_y
I copied this from Allex's former bomber. They're freakin great! High quality, sturdy, and able to withstand up to 30a i believe (not sure though).
Stielz said:BMS needs to be enabled and the cell voltage has to be higher than the "balance voltage" setting in the BMS menu. Then it should start to balance.
Looks like your Max-E is mounted inside the enclosure.. What sort of MOSFET temperatures are you getting up to?
