I am working on my second bike and looking for some confirmation on my motor choice (Leaf 1500 rear DD), or alternate advice.
My current bile is an old sensorless front tire DD kit running at 52v 20a. Runs about 30 mph on flats. It’s a lot of fun but my major complaints are not enough power to deal with hills / headwinds and maintain 30 mph and a lot of stuttering at the start unless I go really lightly on the power (I believe this is due to the lack of hall sensors).
My primary needs are:
First, in town - 25 mph speed limit with lots of traffic lights and basically on a hill (1-6 grade). What I would like to see for this area is 20-30 mph and more power than my current setup.
Second, near my house - 35 mph speed limit with little stopping and relatively flat. I would like to be going 30-40 mph here instead of 20-30. A cruise speed of 35 mph with a top speed of 40 would be ideal so I can deal with a little wind or the occasional hill without losing speed (at the very least without dropping below 30).
My secondary goals are:
I would like to stick with 52v if possible – but if I need to change to meet my goals that could be a future upgrade as long as the system works well enough at 52v.
I have a full suspension Santa Cruz Superlight that I am converting. So unsprung weight is a concern (TBH I don’t know how much of a concern, I would like to get some input here).
Solution:
It looks like a 1500-watt leafmotor running on 52v 40a should accomplish all of my goals except low unsprung weight.
These threads have been very helpful as has the ebike.ca motor sim.
https://endless-sphere.com/forums/viewtopic.php?t=66489
http://endless-sphere.com/forums/viewtopic.php?f=6&t=62939
Other options?
Maybe a 72-volt Mac?
It seems like a mid-drive would be good for this scenario, having different gearing for the 25mph / 35mph and no unsprung weight. Potential for off-roading that I'll probably never use? Maybe a GNG cyclone or X1 Pro? BBS? But the BBS look underpowered for 30-40 mph. And the others have their own quirks and are expensive with drive train wear concerns at highpower.
I guess this was a long post, if you're still reading, thank you! Any reason not to go with the leaf motor? Any advice on the unsprung weight? Anyone really think the mid-drive is the way to go? Other comments?
Thank you!
Solution:
Other options?
Thank you!
