John in CR
100 TW
lostcoyote said:john,
have you taken any physics courses?
center of gravity has to do with mass distribution and specifically, the balancing point (fulcrum or centroid)) of that volume of mass integrated over 3 dimensions..
furthermore, it is independant of whether the body of mass rests on the ground at 2,3, or 4 points or if it floats above a cloud.
http://en.wikipedia.org/wiki/Center_of_gravity
try this simple exeriment:
support a 12 inch ruler on each end with a glass or aluminum can. put your finger on the 6 inch mark and lift. the ruler is more or less balanced on your finger at this point, which marks the rulers center of gravity.
rest the ruler back on the cans or glasses. add a quarter to the 10 inch mark. place your finger back under the 6 inch mark and lift it up again. guess what? the cnetr of gravity of the ruler has shifted away from the 6 inch mark as the 12 inch side tips down.
the bike is no different. center of gravity is determined by spatial mass distribution.
study the link provided above and understand the simple math equations as well as the concept presented.
to add to the experiemnt outlined above, get a 6 long 2x6 board and 2 bathroom scales. place each end of the wood board on the scales.
next, put a 10 pound bag of sugar at the center of the board (the 3 foot point) and measure the scale. assuming a 5 pound board, each scale would record 7.5 pounds.
next, shift the bag of sugar to about the 5 foot position. note that the scale closer to the bag of sugar increases in weight while the scale further away decreases (but each scale adds up to 15 pounds still)
try it.
this is high school physics.
i don't mean to come across as being arrogant here, but your statement that the center of gravity does not change when you add weight over the rear wheel is simply not correct just because it makes contact with the ground. if that was true, then part 2 of the experiment with the 2x6 would indicate that no matter where you place the sugar bag along the 2x6, each scale would always indicate 7.5 pounds.
Lostcoyote,
Yes it is elementary. You forgot to anchor one end of the ruler on the ground. Then it doesn't matter how much weight is added at that point. The rear wheel is the same. Gravity can have no effect once it's already on the ground, and I've been pretty clear about that point all along. I'll give up once it actually clicks for you guys.
John
