zombiess said:
HI madin88,
I just wanted to interject that the power is taken based on battery voltage + battery current. Phase current is not used for power rating calculations. How hot the motor will get depends on many factors, but the dominating factor is battery_current * battery_volts * motor_efficiency.
As an example:
100V battery * 30A current * 85% efficency = 3000W in but only 2550W out. 450W of energy went into making heat.
This is a bit over simplified as the controller efficiency is assumed to be 100%. The entire controller/motor needs to be looked at as a system.
hey zombiess, i go along with you, but i was trying to bring up something different:
once a controller runs into battery limit, it begins to work like a step-down converter - right?
as to the example of the 3000W, 100V rated motor:
while we still have 100V 30A on battery side, there can be for instance 50V and 60A on the motor phases (RMS values). Or 20V and 150A when going up a steep hill.
now someone may think why does my motor overheat when i still only run 3kw?
Well, the motor was not runnnig at the rated specs.
Cromotor as another example:
rated for 5000-6000W continuous at 72V. this results in 70-80A continuous phase.
With this setting it should never overheat. ok, apart from that if someone leaves it stalled for a long time so there is no convection of air inside the motor...
