flange spacing is 49.5mm :wink:
i did a comparison between 4T MXUS V2 and Cromotor V2/V3 (only theoretical):
one strand has 0,5mm diameter so 0,196mm² cross section (same on both)
Cromotor has 18 strands so 3,53mm² windings, 48mm wide stator
MXUS V2 has 16 strands so 3,14mm² windings, 45mm wide stator
MXUS needs 6,6% more current for the same torque output because of smaller stator and it has roughly about 10% higher resistance.
If my calcualtions are correct it would mean MXUS has about 25% higher copper losses at same torque output like Cromotor. Im not sure how much this adds to overall heat output because there are also iron losses.
