markz
100 TW
Got me four MW HRP-300-24, and a set of two are connected in series to achieve 41.5V charge on 1.6Ah 18650 cans.
From no juice left ~3.00V to 4.00V took 24:03 minutes
... to 4.10V took 30.5 minutes
... to 4.15V took 33 minutes
Audible 1st stage fan slow down @ 36 minutes
Audible 2nd stage fan slow down @ 41 minutes
Audible 3rd stage fan turn off @ Soon After 41.5 minutes
As you can see I got an odd-ball MW HRP, it cant go lower then 43V, so I have to keep a very close eye on it, I disconnect at 41.7V, and wait for the other set to completely finish and disconnect it, and connect other battery, takes another 3-to-5. Its a bit of a pain. The major problem is when I am out and about riding, and I want to sit at a Tim Hortons to have a frozen donut reheated, I got to babysit the one set to make sure it doesnt go above 41.7V. I am thinking I can install some wire making a DIY wire wound power resistor, to see if I can reduce it by 1.5V.
I calculated the total charge time to be ~45min (12Ah/16A=0.75x60=45min) seems to be an accurate calculation to determine charge time.
Dimensions
Size of each set (two stacked) 199 by 105 by 82 (each module is [from specs] 199*105*41mm L*W*H) running off of 120Vac input, and ~4A input.
Its bulky, but I figure I will start saving for brand new 3.5Ah cans and for the same size pack, I get over double the Ah.
Alternatives are HRP-600-48 size is 218*105*63.5mm (L*W*H) $145usd($200cad) can do 10S or 13S
But you see I paid $150-$170usd for 5 HRP-300-24 which can do
A) 20.5V-to-29V
B) 41V-to-58V which is 10S or 13S
C) 61.5V-to-87V
I am happy with everything, except the bulkiness of the charging, takes up too much space in my pannier bags.
Alternatives I've been looking at to reduce the overall size for 1200W charging on 115Vac outlets.
Meanwell RSP
RSP-1000-48 43V-55V @ 21A pulls 12A from the wall on 115Vac
the 1500's pull 17A from the wall.
Meanwell HLG (LED Drivers, fully sealed)
Meanwell Clones off ebay.
Dimensions
A) 20.5V-to-29V
C) 61.5V-to-87V
Meanwell RSP
