99t4 said:Are you going to need washers for the hub (spoke holes drilled for 12ga) with your new 14ga spokes?
Not sure. The hub end is 13 gauge so 2.3mm vs 2.6mm.
"Like it says, this spoke is very strong. The Strong is developed for specific and heavy usage such as tandem, e-bikes or heavy load use. In case of large hub holes, the Strong is the recommended choice."
EDIT: I ran numbers through 6 different spoke calculators. Half matched, 3 used slightly different ways of calculating, and once I made some tweaks, they all matched within a couple tenths of a mm. Once the rim arrives and I can measure the actual ERD, I should be set.
Freewheel arrived today, but times two. Something screwed up during ordering, so I've got the second packed and ready to drop off at UPS.
EDIT: Playing with the simulator, comparing a 9C 8T, which seems to model very closely to my 1000W MXUS, with the Leaf 5T in a 24" wheel.
https://ebikes.ca/tools/simulator.html?motor=Leaf%205T&batt=cust_80_0.05_24&cont=cust_70_200_0.03_V&hp=0&axis=mph&frame=mountain&autothrot=false&throt=100&grade=0&wheel=24i&cont_b=cust_70_200_0.03_V&motor_b=M2808&batt_b=cust_80_0.05_24&wheel_b=26i&hp_b=0&bopen=true
I wanted to see what the difference I'll see in acceleration, between the Leaf, and my motor run on both 72V and 52V. I used 78V and 55V for the comparison, since I'm usually above those voltages when out for a short ride (15miles or so). It looks like around a 10% advantage to around 23 mph, then the Leaf keeps going, when the 9C's torque falls off. At 52V, the torque starts falling off after 10mph.
and compared to where the bike started out:
https://ebikes.ca/tools/simulator.html?motor=Leaf%205T&batt=cust_80_0.05_24&cont=cust_70_200_0.03_V&hp=0&axis=mph&frame=mountain&autothrot=false&throt=100&grade=0&wheel=24i&cont_b=cust_70_200_0.03_V&motor_b=M2808&batt_b=cust_55_0.05_24&wheel_b=26i&hp_b=0&bopen=true
I think the interesting zone for torque starts at around 80NM, and just gets more fun above that. That's for my bike and it's laden weight. The midrange acceleration is fun to play with.
EDIT: 12-01-21 Grin shipping is expensive, but super fast. Statorade, torque arm and switches arrived yesterday, and so did the gear puller that I probably won't need. The thermistor will arrive tomorrow, so I'll definitely be able to get to opening the motor and adding both the Statorade and thermistor by the weekend. I ordered 2 thermistors, so adding the other to my existing motor will be a future project.
