reagle
I finally got around to throw it together- basically an 8 channel Seiko S-8209 based BMS with OV/UV and balancing.
The chips are working pretty well, and are very easy to string together. Getting them in the first place is a different story.
I used a separate charge input, with an NMOS FET, and a load output with its own protected high side switch (BTS555 from Infineon). The part is not cheap, but is built like a tank, and with 2mOhm Rdson, it barely flinches running my 20A+ lawnmower motor
The balancing shunts are 6x100Ohms 1206 resistors in parallel- I was too lazy to order 2512 size ones I was planning to use originally, so in go a bunch of smaller ones. They spread the heat well though.
