Excursi0n_AUS
10 µW
- Joined
- Dec 1, 2020
- Messages
- 5
Hi folks,
Super keen "no pun intended" to get some help from you guys and gals.
I am new to the forum so I hope this is the right section to get started.
I have been doing some minor mods to my Super73 because, ya know... COVID.
I know from the start that its probably better to just buy another bike but I love the tinkering and learning experience so please try to avoid the advice "just buy a different one".
I am a level 3 noob when it comes to this stuff and everything is self taught so be gentle.
I have added an additional 17aH battery
Front suspension forks
New crank assembly
New Chain
New Handlebars
Custom seat
New decals and stickers
New duel headlights (I think I shorted the light circuit in the controller when connecting them) They remain on 100% of the time, along now with the rear light. Only disconnecting the battery turns them off. Would like to fix this but not a priority.
To get started I would love to know what the motor is actually capable of?
Currently I have got it up to 35kph is that as much as I will get from a 48v battery? Any advice on testing?
I hear many people with 48v bikes going way faster but, as I said, noob here.
It says 250w on the outside it but I have a feelings its just a compliance sticker....
I replaced the throttle display with a newer unlocked version that gets me up to 36.5kph boost for a few secs and drops to 35kph constant.
If I test with the wheel lifted it will do 41kph boost and 36kph constant.
I popped up a few pics of the motor if it helps a pro identify it.
I get the impression that the controller is where the real magic seems to happen so perhaps all I need is a new controller?
If that is the case how do I find a compatible one with all my existing bits and bobs?
I popped up a picture of the current controller spec.
Seems the only "odd" thing about this is the "throttle adjustment voltage"... Finding it hard to get one that matches
Many online sellers refer to "speed set" I assume "throttle adjustment voltage" and "speed set" are the same thing. Would love if someone could confirm that. I also think this is a SINEWAVE controller, would be good if someone could confirm that too.
I have soooo many questions to ask hopefully this start isn't to daft.
Thanks in advance!
New crank assembly
New Chain
New Handlebars
Custom seat
Thanks in advance!
