PaulD
Drum said:One correction however, brazing (despite the name) uses BRONZE rod, not brass, as the filler material. Bronze is stronger and more corrosion resistant than brass.
Hi Drum,
The terminology of brazing alloys is rather confusing. I used C-04 brazing rod from http://www.gasflux.com/brazing.html. It is an alloy of mostly copper and zinc with some other additions. They list it as "Bronze"
Technically, bronze is an alloy of copper and tin, and brass is a alloy of copper and zinc.... so, I've always called the brazing rod "brass" because of the composition, but others call it Bronze...
-Paul
