michaelP
🧲 New user
- Joined
- Jan 9, 2023
- Messages
- 4
I’m want to buy a specific eScooter model (M1P CitiCoco chopper) that is manufactured with a variety of motor, controller, and battery specs combinations. I ride on mostly flats and want the config that provides highest top speed (ideally ~ 45mph/72kph). Motors offered are 60v/2000W, 2500W, 3000W. Ctlrs range from 60v/45A to 80A. Batteries are either 60v/20Ah or 30Ah. Motors are made by QS Motor Co. based in China.
I’ve read several bat/ctlr/hub motor opinions on internet and this forum. But some opinions seem to conflict. I’m trying to decide on best config (bat-ctlr-motor) for top speed along with motor/battery longevity and performance. My priorities are ranked in preference as Speed first, range distance second,, and acceleration last. I prefer 45mph for road use, and range distance around 30-40 miles per full charge. I weight 170 lbs/77kg. Scooter weighs 200 lbs. Negligible wind on flats.
My confusion/indecision is based on compatibility between bat/ctlr/motor for best speed and longevity of motor/bat. Most of the motors for this model are geared, not DD, which doesn’t help top speed much when ramping up amperage (I think??)
Am I correct in assuming:
1. all three should be rated at 60 volts.
2. Battery choice with highest Ah/wattage.
3. Ctlr amps-out should be at or slightly less than motor’s max capacity rating.
4. Not sure if ctlr should be square or sine.
5. Not sure if I should be concerned about ctlr’s number of MOSFETs (6,12,18,24, etc)
6. Some say the ctlr amp max should be less than the battery amps output; while others say ctlr’s max amps out doesn’t matter, since motor will restrict only the amps it can handle under load. While others warn that too much amperage from ctlr will heat-up motor and burnout.
So I would greatly appreciate suggestions for best amp/watt compatibility with all three at 60 volts; and for highest top speed and longer range distance per charge.
